Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 54
  1. #11
    Benefit of hosting on a VPS package is that you get complete root access to your environment. This way, if you need a custom software package installed, you can do so without having to wait for your hosting provider to support it.
  2. #12
    A VPS internet hosting service account is less expensive than a full dedicated internet hosting service plan that uses a physical server.
    Many VPS plans can be customized to meet your needs so you pay for what you want but you do not need to deal with any features you will never need.
    Many VPS internet hosting service plans are easily scalable. You can start off in your virtual environment with the minimum amount of resources you need and then as you grow gradually increase your internet hosting service plan to accommodate your needs. You do not have to pay for excessive resources you have not yet grown into.
    You have a lot more control over your virtual server than you do with shared internet hosting service. You will likely have root access and the ability to use scripts that may not be allowed in the shared internet hosting service environment.
    You have the same technical support as with shared internet hosting service for most issues.
    You can choose from semi managed internet hosting service where the web host handles some maintenance and fully managed services.
  3. #13
    VPS Hosting allows for custom configurations and installations, because it gives you full root access to the virtual server. This is feasible because you are the sole owner of the VPS. Absolutely independent OS can be installed and configured on every virtual server of the VPS host.
  4. #14
    it's used for larger websites
  5. #15
    VPS has more secure hosting provide.VPS provide various features.
  6. Default
    Read through the plan you have selected and write down on a piece of paper what they are offering you. Do you understand everything? If not find out what it means because you don’t want to sign up for 1 year and then figure out that there is a difference between addon domains and parked domains.
  7. #17
    There are following benefits of VPS hosting.
    • It a good option if you have a limited number of blogs and smaller websites as it is easy to maintain.
    • It has an economical advantage.
    • Technical maintenance of the server is not required, therefore you do not need a special skill set to handle your website.
    • You can demand for extra storage space.
    • All kinds of software, including virtualized software can be installed.
  8. #18
    Have you solved your issues already?
  9. #19
    The main advantage of a VPS over a typical Shared or Reseller hosting account is that you can install the software and configure almost every detail to the way you want it allowing you to take your website(s) or project(s) to another level.
  10. #20
    Quote Originally Posted by Bloxup123 View Post
    Great post thanks for sharing such nice information
