Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 47
  1. Default
    VPS give you full control , like you use your computer but it online 24/24
  2. #12
    Jul 2015
    Pekanbaru
    21
    i think to more stability your web, if you have much visitor.. and also our can make high security in our server.
  3. #13
    Informative. Thanks for it.
  4. #14
    With a VPS Server, you have your own Operating System. This also means that you have your own instances of all server applications such as Apache, PHP, and MySQL. If you need to have any of these services customized, you can make changes to suit the server to your needs.
  5. #15
    really lots of good questions, but it's for large scale websites
  6. Default
    Even if they do not need all the system resources allocated to them in the VPS and a shared environment is just as suitable, the control they are afforded is worth the added expense.
  7. Default
    VPS Hosting is like owning a Condo. While regardless you share things on the property, you are at last in charge of keeping up your own property and repairs inside the townhouse. There is likewise altogether less inhabitants per fabricating and alloted stopping. On a Virtual Private Server, you are dispensed assets that are not shared by everybody. The over all CPU time and memory are shared over all records on the machine, however in the meantime parcels of those assets are constantly committed to every record. This takes into consideration more power and adaptability than being on a common record. For more data see the accompanying PDF.
  8. Default
    Shared Hosting includes our Business Class Hosting Plans. Shared Hosting is very similar to living in an Apartment Complex. All residents are in the same location and must share the available resources with everyone.These may include such things as the pool, parking lot, and play ground. In shared hosting, all accounts must share the available resources with all the other accounts on the server. These include CPU time, memory, and disk space. Want to compare shared hosting? Check out InMotion Hosting vs. HostGator.
  9. #19
    If you dont have to much traffic to your website its much cheaper than dedicated hosting.
  10. #20
    VPS is fast, reliable and very supportive for the visitors. It can handle thousands of visitors at a time. Downtime is very less in VPS.
