Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
  1. Default What’s difference between Stack and Queue?
  2. Default
    Stack and Queue both are used as placeholder for a collection of data. The primary difference between a stack and a queue is that stack is based on Last in First out (LIFO) principle while a queue is based on FIFO (First In First Out) principle.
    Thanks
    Priya
    Hopinfirst.com
  3. Default
    Stack is a LIFO (last in first out) data structure. The associated link to wikipedia contains detailed description and examples.
    Queue is a FIFO (first in first out) data structure. The associated link to wikipedia contains detailed description and examples.
  4. #4
    Quote Originally Posted by priya01 View Post
    Here I attached 2 images that showing the operations done on stack and queue. In stack these operations are known as pop and push and in queue its enqueue and dequeue.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1188   Click image for larger version.
  6. #6
    Stack and Queue are both techniques are used into data structure.Stack use LIFO technique and Queue use FIFO technique........
  7. Default
    Stack and Queue both are linear data structures can be implemented both in array and Linked List. Stack is a data structure where the data that enter first will be retrieve in Last (FILO), but in case of Queue the data that has enter first would be first to left (FIFO) the counter.
  8. #8
    Jan 2015
    Ludhiana,Punjab,india
    224
    Stack is based on last in first out and queue is based on first in first out.
  9. #9
    Stack has one entry point where as queue has input from one end and output from second end .
  10. #10
    A stack is a collection of objects in which objects are accessed in LIFO (Last in first out) fashion. Whereas aqueueis a collection of objects in which objects are accessed in FIFO(First in First out) sequence.
  1. WHat is the difference between cs5 and cs6?
    By Dominic hunter in forum Photoshop
    Last Post: 09-03-2018, 23:48 PM
  2. What is the difference between PPC and CPC ??
    By chinmay in forum Internet Marketing, SEO, PPC, Web Development Forums
    Last Post: 12-30-2015, 02:56 AM
  3. What is difference between SEM and SEO?
    By snehasaini in forum SEO Forum
    Last Post: 11-19-2013, 04:50 AM
  4. Difference Between JVM and JRE
    By keirawtsn in forum Computer Forum
    Last Post: 04-21-2013, 19:19 PM
  5. Any plan to dedupe the queue?
    By ansonbrook in forum Web Hosting Forum
    Last Post: 11-16-2010, 16:58 PM
Tags for this Thread
