Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
  1. Default What is the difference between superclass and subclass?
    Thanks
    Priya
    Hopinfirst.com
  2. Default
    You can search on Google
    super class is the base class and sub class is derived from super class. subclass inherits all the properties of super class and a sub class can use all the methods and properties of super class. but super class can use the property of sub class. and for more as tranngoi suggested search on google.
  4. Default
    A super class is a class that is inherited where as subclass is a class that does the inheriting.
  5. Default
    Super class is the base class and sub class is derived from super class. subclass inherits all the properties of super class and a sub class can use all the methods and properties of super class. but super class can use the property of sub class. and for more as tranngoi suggested search on google.
  6. #6
    Subclass is a class that derives from another class. A subclass inherits state and behavior from all of its ancestors. The term superclass refers to a class's direct ancestor as well as all of its ascendant classes.
  7. #7
    Super class is base class also known as parent class. And the sub class, also known as child class, is the derived form super class. Sub class inherits the functions and properties of parent class.
    Parent Class(Super Class)
    Child class(Sub class)
  8. #8
    The class from which it's derived is called the superclass.The derived class (the class that is derived from another class) is called a subclass.
  9. Default
    super class is the base class or parent class while sub class is derived from super class.sub class inherit the properties of parent class.
  10. #10
    Super class refers to a high level class, which passes some kind of attribute and procedures. This is usually followed down to the hierarchy to subclasses. Most of the time abstract super classes are referred to as master structures and almost most of the time no objects are created for it.
    On the other hand, a subclass is that inherits different kinds of specifications and also behaviors. This could also include methods, procedures and variables from any other class.
  1. Difference Between DNA and RNA...?
    By sofiajain in forum General Discussion
    Last Post: 02-10-2016, 08:31 AM
  2. WHat is the difference between cs5 and cs6?
    By Dominic hunter in forum Photoshop
    Last Post: 10-08-2015, 17:39 PM
  3. Difference Between SEO and SAS ...?
    By nishajain1421 in forum General Discussion
    Last Post: 08-24-2015, 06:27 AM
  4. Difference Between WAV and WMA
    By edwrdwlsn in forum Computer Forum
    Last Post: 04-21-2013, 16:54 PM
  5. Difference between SEM and SEO ?
    By farmgate in forum Google Forum
    Last Post: 03-14-2013, 06:44 AM
Tags for this Thread
