Results 1 to 9 of 9
    Thumbs up What is an Iterator class?
    A class that is used to traverse through the objects maintained by a container class. There are five categories of iterators:
    random access.
    input iterators
    forward iterators
    output iterators,
    bidirectional iterators.
    An iterator is an entity that gives access to the contents of a container object without violating encapsulation constraints.
    In computer programming, an iterator is an object that enables a programmer to traverse a container, particularly lists. Various types of iterators are often provided via a container's interface.
    Thank you~!
    Mar 2017
    california
    69
    Iterator is a design pattern. It specifies how to navigate through the elements of a collection. Collection is a collection like array, stack, list.
  4. #4
    Java iterator is an interface belongs to collection framework allow us to traverse the collection and access the data element of collection without bothering the user about specific implementation of that collection it.
    An iterator is an object that enables a programmer to traverse a container, particularly lists. Various types of iterators are often provided via a container's interface.An iterator over a collection. Iterator takes the place of Enumeration in the Java Collections Framework. Iterators differ from enumerations in two ways: Iterators allow the caller to remove elements from the underlying collection during the iteration with well-defined semantics. Method names have been improved.
  6. #6
  7. #7
    In computer programming, an iterator is an object that enables a programmer to traverse a container, particularly lists. Various types of iterators are often provided via a container's interface.In computer programming, an iterator is an object that enables a programmer to traverse a container, particularly lists. Various types of iterators are often provided via a container's interface.
  8. Default
    An iterator is an object that represents a stream of data. An iterator is a generalisation of a pointer, used for abstracting addresses of elements of different structures.
  9. #9
    Jun 2018
    Emeryville, CA
    116
    Iterator is an interface and a object which enables a developer to traverse a container, particularly lists. Iterators are used in Collection framework in Java to retrieve elements one by one.
  1. What is list iterator ?
    By Shivangi Panwar in forum Programming
    Last Post: 01-26-2019, 06:41 AM
  2. What is an Iterator class?
    By chinmay in forum Programming
    Last Post: 04-26-2016, 07:15 AM
  3. What are inner class and anonymous class?
    Last Post: 02-25-2016, 07:09 AM
  4. Class C IP’s
    By xicshost in forum Webmaster Forum
    Last Post: 07-17-2012, 08:57 AM
  5. C Class IP and SEO
    By officespace in forum Internet Marketing, SEO, PPC, Web Development Forums
    Last Post: 11-14-2011, 13:09 PM
