Results 1 to 4 of 4
    Default How about BlueHost independent IP
      How about BlueHost independent IP?
      BlueHost is a kind of shared hosting with stable performance and fast speed, especially suitable for foreign trade site building. It has independent IP, which can keep users from being affected when attacks happened, and reduces the probability of IP being blocked. So, how about BlueHost independent IP, please look at the following introduction.
      The advantages of BlueHost independent IP :
      1, Avoid any involvement in attacks: when the shared hosting under the same server suffered from attacks, the shared hosting that has independent IP shared hosting will not be affected, and will not result in breakdown 。
      2, When an IP corresponds to a website, the search engine will think highly of this site, you’ll get a better page rank, and your website will get indexed by the search engines; while shared IP don’t have these advantages.
      3, Resolution and binding of extensive domain name: you can bind the extensive domain name on Windows shared hosting when use independent IP , and the user can also resolve the domain name to an independent IP, you can access even without binding.
      4, Help the encryption of https : for some e-commerce sites or some other sites that need to encrypt https, they will realize it through independent IP.
      5, Low price of independent IP shared hosting: independent IP shared hosting not only has the same advantages as common hosts ,but also has the low price 。 BlueHost‘s Plan C provides independent IP for free.
      6, Users who use shared IP to build sites can only access the site through the domain name, can not access by IP address. As for the site built with independent IP, can be accessed directly through IP.
      Above are the introductions about BlueHost independent IP. In short, it is important to use independent IP to build foreign trade sites,in order to better serve our customers, and BlueHost’s independent IP is still very cheap.
    thanks
    It was an amazing info.
  4. #4
    well explained
  1.  Which is Better Between Independent IP and Shared IP
    By xiaolanzhuji in forum Web Hosting Forum
    Last Post: 03-16-2018, 01:41 AM
  2.  Recommend independent IP for BlueHost
    By xiaolanzhuji in forum Web Hosting Tutorials
    Last Post: 12-20-2017, 05:54 AM
  3. Bluehost hosting and bluehost review
    By charlesgan in forum Web Hosting Reviews & Rating
    Last Post: 03-06-2017, 12:06 PM
  4. How can say? Java is platform independent language.
    By David Alessi in forum Programming
    Last Post: 08-05-2014, 09:27 AM
  5. Independent Back Linking Networks
    By admans in forum Ad Revenue
    Last Post: 08-07-2005, 11:36 AM
