Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 44
    Feb 2015
    India
    113
    Default What are the disadvantages of Shared hosting? and limitations?
    What are the disadvantages of Shared hosting? and please mention its limitations?
  2. Default
    Despite the number of advantages that shared hosting plans bring to their clients, it also has its share of disadvantages. These are the common disadvantages of shared hosting plans:
    • The biggest disadvantage of shared hosting is the security issues that the server faces.
      o Shared servers are usually prone to hacking attacks.
      o Any malicious activity that the server suffers affects the whole network of websites using the server.
    • As you need to share the resources of a single server, your website my often experience sluggishness brought about by the request for resources by other sites.
    • You may experience resource limitation as everybody else in the network uses the same CPU, memory and hard drive.
    • Server may get swamped by requests or overloaded which might cause it to stop.
    • Your hosting plan may have lesser features compared to dedicated hosting plans.
    • You do not have the choice over the software and application that you want to use as you cannot use any other software aside from what is provided by the hosting provider.
    • The customer support may not be as good as those of dedicated plans.
    • Because of security policy, some available port and connections may be limited.
    A shared hosting plan hosts multiple accounts on a single dedicated IP address. They are usually used to save costs and space for hosting. Shared hosting is not very recommendable as they do not provide data security as the same space and IP address is shared between multiple clients.
    Cheap VPS Hosting | VPS Starting from $1
    Cheap Dedicated Server |
    Free IPMI
    Windows VPS |
    Windows with Remote Desktop
  4. #4
    First disadvantage of shared hiringh is lack of security, when you use shared hosting then there will be more chances of website hack like injecting malicious code.
    Shared housing lies on single server so it is limited to a particular Geo location. Shared housing can withstand till to some extent only, once it reaches bandwidth meeter then it does open.
  6. Default
    There are various limitations of Shared Hosting are as follows:
    1. System Crushes
    2. Performance Problem
    3. Security
    4. Security issues that the server faces.
    5. The server may get swamped by request or overloaded which might cause it to stop.
  7. #7
    The biggest disadvantage of shared hosting is the security issues that the server faces. Shared servers are usually prone to hacking attacks. Any malicious activity that the server suffers affects the whole network of websites using the server.
  8. #8
    Shared hosting is just like sharing a room. You do not have much say about a lot of things, and when the room gets crowded, you will feel it.
  9. #9
    will you tell me the disadvantages of Shared hosting? and limitations?
  10. #10
    Feb 2015
    India
    113
    Quote Originally Posted by damponting44 View Post
    1. System Crushes
    3. Security
    As you rightly said performance is the biggest drawback in shared hosting and most of the times it will not open, takes too much time to load because of server response time is high.
  1. What are the problems and the disadvantages of free web hosting..?
    By preetising4321 in forum Free Web Hosting Discussions And Reviews
    Last Post: 09-10-2018, 08:47 AM
  2. Disadvantages of Cloud hosting
    By sevenl in forum VPS Forum
    Last Post: 06-13-2018, 01:33 AM
  3. Replies: 0
    Last Post: 01-09-2018, 04:13 AM
  4. Advantages and disadvantages of free web hosting
    By sevenl in forum Free Web Hosting Discussions And Reviews
    Last Post: 01-05-2017, 06:49 AM
  5. Free web hosting Facilities & Limitations
    By top9 in forum Web Hosting Forum
    Last Post: 02-21-2014, 06:23 AM
